Bound to happen - starter out
Old Oct 11, 2016 | 03:52 PM
stillruns's Avatar
Default Bound to happen - starter out
I suppose it is the starter. Go to crank it and the machine gun "click click click" happens. No turnover. Dash lights work. If not the starter..? Any good recommendations for a new one?
Thanks
98 D1
Old Oct 11, 2016 | 08:03 PM
jastutte's Avatar
don't know about new but Will Tillery sells used starters pretty reasonably. though you may be located closer to one of the other dismantlers.
Old Oct 11, 2016 | 10:24 PM
XCELLER8's Avatar
are you sure the battery is good ? and the ground cables may need attention too
Old Oct 12, 2016 | 07:45 AM
WaltNYC's Avatar
Here is an interesting site for starters. I've heard good things.
British Starters
I replaced with one from British Atlantic and have been happy.
Old Oct 13, 2016 | 05:56 PM
stillruns's Avatar
Turns out i jumped it and it works fine. I only drive it once a week so maybe thats the problem. I'll crank it more frequently.
Old Oct 15, 2016 | 08:48 PM
Mark G's Avatar
Clean your battery connections really well. Happens a lot.
Old Oct 16, 2016 | 09:34 AM
stillruns's Avatar
That I need to do toward the bottom end. Cables on top at battery are solid and clean, plus new battery. But when you follow the cable down it gets dark and saturated with oil..of course. What exactly would I clean it with and where does the cable end? At the starter I suppose?
Old Oct 16, 2016 | 11:56 AM
aemnky606's Avatar
Yes it goes to the starter. I would use a can of electric parts cleaner on the starter and wire ends, if there is a lot of build up brush with a brass brush to knock it all off.
CRC Electric parts cleaner 05718- ReadReviews onCRC #05718
Old Nov 15, 2016 | 07:12 PM
2004DISCO's Avatar
I am having similar problems, trying to diagnose properly, I have a 2004 Disco. My engine clicks (machine gun clicks) but no start, battery is good as I checked the voltage and Cold cranking amps. I am assuming it is the starter... I was going to take it off tonight but didn't have proper tools on me (car stranded at my marina) I also noticed that my head gasket problem drips right down on the starter, it is super wet around the Vbatt and GND terminal. Will clean that first tomorrow before I take the sucker off and get it checked.
Old Nov 18, 2016 | 08:23 PM
stillruns's Avatar
If i go more than 4-5 days without cranking mine it won't turn over. If i hook jumper cables to it it turns over immediately. I've had to do this more often now. I'm not sure if I need to replace the starter or what. Both the starter and alternator are original from 1998. Maybe that should be a hint.
