Bound to happen - starter out
Old 11-19-2016, 07:02 AM
JUKE179r's Avatar
Originally Posted by aemnky606
Yes it goes to the starter. I would use a can of electric parts cleaner on the starter and wire ends, if there is a lot of build up brush with a brass brush to knock it all off.
CRC Electric parts cleaner 05718- ReadReviews onCRC #05718
I guess this can be done on all motors. Even the alternator?
Old 11-19-2016, 04:33 PM
2004DISCO's Avatar
Originally Posted by stillruns
If i go more than 4-5 days without cranking mine it won't turn over. If i hook jumper cables to it it turns over immediately. I've had to do this more often now. I'm not sure if I need to replace the starter or what. Both the starter and alternator are original from 1998. Maybe that should be a hint.
How is your battery? Is that also from 1998? haha
Check that before you do anything else.
I finally fixed my starting problem today, changed the starter "TWICE", Installed it the first time and when I was about to plug in the ignition wire the ****ing thing broke off of the starter, almost made me cry. I had to pull the starter off again, take it home, solder the ****ing piece back on and put it on again... It started on the first try after that...
Old 11-19-2016, 05:18 PM
stillruns's Avatar
Battery is new. Just threw in an Interstate a few weeks ago. 4-5 days of sitting and no crank. I do have oil saturated the starter end of the line. That leaves the starter and alternator i guess. Both of which need to be replaced but i'm pretty stoked they got 18 years of use and still going. Alternator i can do myself. Starter not so much. May research some local shops. If i ran into the situation you did i would be up the creek since i dont have any soldering eq.
Old 11-20-2016, 05:39 PM
2004DISCO's Avatar
Starter is not bad either, its a bit messy but doable. Like I said I took mines off twice yesterday... you will need a 24 inch extender for the top bolt and a Swivel Ratchet Wobble, they are torx bolts so you will need a torx set.
Old 11-20-2016, 07:12 PM
stillruns's Avatar
Did you crawl under it and do the work or use ramps? Lift? Seems like it would be a bear having to lie underneath it.
Old 11-21-2016, 07:16 AM
2004DISCO's Avatar
I just crawled under it and did the work. But then again my Disco has a 3 inch lift so I can just crawl under it whenever I need to do something, change the drive shafts, oil, starter, etc...
Old 11-21-2016, 10:23 AM
JUKE179r's Avatar
I installed a quick disconnect on the negative side my Disco's battery. This is to disconnect the battery if I park it and plan to be out of town for more than a couple of days.
The downside is that I'll have to reprogram the radio stations on my Sony radio but I normally use my iPod.
Old 11-21-2016, 07:40 PM
stillruns's Avatar
Any pics or specs on the quick disconnect? I like the idea since mine is not a DD.
Old 11-21-2016, 07:41 PM
stillruns's Avatar
"I guess this can be done on all motors. Even the alternator?"
I bought a can yesterday and sprayed the heck out of the starter, well, at least what I could hit. It has a heat shield that blocks most of it. Had to crawl underneath it.
Old 11-22-2016, 08:03 AM
2004DISCO's Avatar
That heat shield is just snapped on to the starter, you can move it out the way easily, but it's also held with a screw so it wont come off.
Quick Reply: Bound to happen - starter out
