braided flat wire connected to what?
Old Aug 7, 2017 | 04:31 PM
rjlsierra's Avatar
Default braided flat wire connected to what?
i have a 97 d1 and can't figure out what the pipe on passenger side by tranny is connected to,there's a flat braided wire which i guess is from starter but when i follow the pipe back it ends pinched and bolted,the front by the wire is capped with a rounded bolt,it's kinda driving me nuts! any help would appreciatei know it's all original and never been altered cause i've had truck for 20yrs,it's probably something simple but would like to know!
Old Aug 7, 2017 | 05:56 PM
aemnky606's Avatar
Ground strap.
Old Aug 7, 2017 | 06:07 PM
rjlsierra's Avatar
thanks,i figured it was a ground but whats the pipe for,doesn't seem to connect to anything
Old Aug 7, 2017 | 07:23 PM
aemnky606's Avatar
I know the transfer case tie bar is in that same area, it may be that.
Old Aug 7, 2017 | 07:33 PM
rjlsierra's Avatar
i think your right since it goes back to transfercase,just seemed like it would contain fluid but with nowhere to go that's got to be why it's there,i figured the strap was ground from starter,thanks for response or if we're both wrong maybe someone knows more!
Old Aug 11, 2017 | 12:14 PM
rjlsierra's Avatar
the main reason i asked about the pipe was i see a small amount of coolant [green color] not really dripping but is there and was wondering where it might be coming from,the only thing above it might be the heater or could it be coming from the head which is forward of it,i noticed this when cleaning the ac drain tube and that's the only fluid i see dripping around there,appreciate any imput
Old Aug 12, 2017 | 10:54 PM
ihscouts's Avatar
If it's coolant it sure could be a head gasket leak. Feel around the back of both heads and primarily the passenger side where you say your hearing the sloshing sound.
Old Aug 13, 2017 | 09:07 AM
rjlsierra's Avatar
is it possible to be leaking coolant from intake manifold?
Old Aug 13, 2017 | 10:27 AM
ihscouts's Avatar
The back intake coolant ports are blocked off by the intakes runner but it can leak past the valley pan gasket. Check the intake bolts for torque, 35 ft/lbs if I remember, aint much and usually loose as heck. The heads are not sided, in other words you can put the left on the right and vice versa, one head design fits both sides.
Old Aug 13, 2017 | 11:57 AM
rjlsierra's Avatar
just went down to look at access to passenger manifold bolts but the back ones are hard to get a 13mm on, the coil and other piping block good access but i am going to try again and cinch them down
johnbbensonjr
Apr 17, 2016 08:47 AM
G150driver
Oct 15, 2015 02:47 AM
Hawkeye712
Aug 31, 2015 03:44 PM
blurover
Nov 29, 2013 01:26 PM
GeorgeD
Mar 13, 2009 07:46 PM
