brake doesn't reach brakelight switch
you mean to turn the brake lights off, right? when i bought a new switch, the plunger was pushed in too far, and after pulling it out some, it was long enough so that depressing and releasing the pedal turned it on/off. Maybe you need to play with the length of the plunger on the switch, if i'm reading your thread correctly
yes you are reading the thread correctly and i've already pulled the plunger all the way out and still have about a 1/4 inch of space.
i think this is the reason for the problem. when i bled the brakes, i replaced the brake booster. probably when i reinstalled that i didn't line it up right or something.
