Brake fluid leak
Old Jan 21, 2013 | 07:29 AM
Sarge103's Avatar
Default Brake fluid leak
I have been noticing that my brake pedal almost goes to the floor before any stopping power occurs. Well on my way out to the parking lot at work i found a small puddle under the front driver side tire and this is what i found. Im just wondering what are the 2 brake lines going in to is that a valve or connector of some sort? and if so is it the line that usually leaks or that cylinder thats connecting the 2 lines? Im just trying to find out what i need to replace, Any help would be appreciated.
Old Jan 21, 2013 | 08:37 AM
fishEH's Avatar
I think that's a coupling/union fitting but its hard to tell. That line is toast though. I'd replace it ASAP and also check all the other lines.
Rover Chris
Oct 12, 2015 06:03 PM
mbeasom
Apr 29, 2011 09:31 AM
bantham1
Nov 8, 2010 03:55 PM
tubadude
Jan 12, 2009 09:36 PM
starcraft
Oct 16, 2007 06:02 PM
