Brake Pedal Goes to Floor
Old Jul 9, 2017 | 11:28 PM
DiscoCam's Avatar
Default Brake Pedal Goes to Floor
So I drove my D1 about 70 miles today, did some wheeling too. No issues whatsoever. I've been needing to change my front brake pads so I did so when I got home. I finished the front driver side brakes then went to pump the pedal to bring the fluid level down a bit from pushing the caliper back in. But the pedal just goes to the floor. Makes a squeak too if I pump it fast. I tried to see if I could bleed the caliper and barely any fluid came out. Do I have a bad caliper? If I do, what should I buy? Rebuild the current one, buy a rebuilt one, buy a brand new one? Should I replace both front calipers?
Thanks in advance
Old Jul 10, 2017 | 10:59 AM
whiskeynipple0088's Avatar
sounds like you got air in the line and soon to be bad caliper - or its just clogged with crap as mine was and was nearly seized.
NAPA has good reman'd calipers - I know this after having one from advanced auto leak and ruin my brand new rotor and pads.
I would also check your brake lines where the coupler is - just under the drivers footwell. - I had mine fail on me - replaced all of those too.
should you do rotors too - check Rockauto - they had Brembro on fire sale for a while - like $25 ridiculously cheap
I would do both calipers (if not pads and rotors too) at the same time.
Old Jul 10, 2017 | 04:12 PM
DiscoCam's Avatar
Brake lines look good so I'm not worried about that.
Not sure how air would get in the system but I guess its through the bad caliper. Just ordered 2 reman ones from Summit. $47 each with a $45 core charge.
Rockauto ran out of the front brembos, called to make sure. Only had the rears left. Would've bought the front ones if they still had them.
Also, after looking everything over a little more, the master cylinder looks fairly new, maybe 2 or 3 years old. Front wheel bearings are toast, good amount of play in the wheels. Rear seems ok. Don't think this should mess with the brake pedal feel that much (when not moving) but still worth mentioning. So 2 wheel bearing kits are on order as well.
Thanks for the input. Much appreciated.
Old Jul 10, 2017 | 04:42 PM
ok hold up - your D1 is a 1999 - correct? They changed models mid year - double check part numbers but I think you may want to be looking for parts for a 98 on rockauto - or in general to reduce the risk of getting D2 parts.
i just checked rockauto Brembro 25142 are in stock
https://www.rockauto.com/en/catalog/...hub,rotor,1896
I just put these exact rotors on my truck 6 months ago
- I would recommend taking the time to clean the inside of brake cover of collected grim/grease while you have the rotor/hub assembly off
not sure if you have air or not but its usually air or a leak
Old Jul 10, 2017 | 04:48 PM
OverRover's Avatar
IMHO good luck with the A1-Cardone rebuilt calipers. They never replace the channel seal, and 9 time out of 10 just sandblast the front of the pistons. Then just cover everything in paint. Also look at the 2 seals and the metal ring. You can find the wiper seal folded and the metal ring bent. This company does 1/2 A$$ work at best.
For my money, unless I'm going to do the rebuilding (especially a brake caliper), I'm NOT buying rebuilt anything. Remember a rebuild is ONLY as good as the CORE and the quality of parts used/installed.
When you get the calipers inspect them really well and save your receipt. Good Luck!
Old Jul 10, 2017 | 07:53 PM
for what its worth - this is a shot of one of the rear calipers I have to put on my D1 from napa
appears to be reused piston with new seal, can tell they are painted prior to joining halves - fronts were the same.
Attached Thumbnails Brake Pedal Goes to Floor-img_1003.jpg   Brake Pedal Goes to Floor-img_1004.jpg
Old Jul 10, 2017 | 08:41 PM
OverRover's Avatar
I think you are proving my point re: reman/rebuilt junk. They reuse as much as they can, paint the part pretty, and for about $50 retail the price seems good. IMHO, total B$!
You can rebuild that rear caliper for $25-$30 in parts including new pistons and 30 minutes of bench time. The front caliper parts are about the same price. Again it's just my opinion, but I don't trust a part to be rebuilt to proper spec unless I do it. It's just too easy for companies to do a "cost effective" crappy job. And please don't get me started on the B$ warranties they offer.
Old Jul 10, 2017 | 08:54 PM
just trying to give an observation of parts I have used, for comparison.
Old Jul 10, 2017 | 09:03 PM
OverRover's Avatar
No worries, I think my post, or maybe it's a rant, was directed at the rebuilders. I have seen so many (and the list is long) put out garbage product it just drives me nuts. Especially when the part is a brake component!
Old Jul 10, 2017 | 09:30 PM
no.... I get it - theres tones of crap out there, thats why I was like - hey these are decent from my experience.
