Brake Pedal Goes to Floor
Old Jul 18, 2017 | 07:32 AM
  #21
AbnMike's Avatar
Do you hear any whooshing/air sound at the brake pedal when you apply them? I had the whoosh/air sound, just slightly down there.
I just replaced my MC and brake booster and good lord, I finally have brakes in my jacked up truck.
Good tip on the above re: passenger side needing attention. I noticed after doing my brakes a slight pull to the left, so I'll hit the passenger side caliper again.
Old Jul 18, 2017 | 09:36 AM
  #22
whiskeynipple0088's Avatar
"Do you hear any whooshing/air sound at the brake pedal when you apply them? I had the whoosh/air sound, just slightly down there. "
I have heard that sound since I got my truck at 62k - now at 108k sounds the same.
How could you tell the booster was bad?
Old Jul 18, 2017 | 09:37 AM
  #23
AbnMike's Avatar
Well my new one doesn't make any whooshing/air sounds
I did a combined MC and Brake Booster replace so it could have been either.
ETA: I forgot that the brakes always felt - bad - can't explain it. I know a few times when cold and backing out of my driveway (which is on a hill) it took everything I had to press the brakes in and get them to actually stop the truck.
Old Jul 18, 2017 | 10:00 AM
  #24
you got me thinking- yeah they've always been mushy never really felt confident with them -
some good info:
http://www.freeasestudyguides.com/br...operation.html
Old Jul 18, 2017 | 01:20 PM
  #25
DiscoCam's Avatar
some good info:
Vacuum Brake Booster Problems Operation Diagnosis
I do hear a whooshing sound when applying the brake. But my D2 made the same sound so I never really thought much of it.
When to bleed the brakes again today. And now I see that there is no fluid coming out of the rear lines. Caliper pistons seem to move freely but. I disconnected the lines at the calipers and pressed the pedal to see if anything came out of them. Nothing came out and the pedal was hard as a rock.
I did hear somewhere that the pressure restricting valve would cut off fluid flow to a line requiring too much fluid (i.e. a leak). Not sure if that's true or not.
All my lines seem fine and being a California truck I doubt there's any line that rusted out.
What should I do now?
Edit: I cracked open the lines going to the back at the ABS pump and same thing, hard pedal, no fluid coming out. Wondering if I disconnect the battery would fluid come out? I'm thinking that maybe something is going on inside the pump blocking fluid from coming out?
I did the same thing yesterday and got brake fluid coming out so fast that I got sprayed in the face so I'm not sure why that's not happening now.
Old Jul 18, 2017 | 03:36 PM
  #26
"I did hear somewhere that the pressure restricting valve would cut off fluid flow to a line requiring too much fluid (i.e. a leak). Not sure if that's true or not."
This did NOT happen when my lines failed.
my guess is to start looking up the signs of a bad proportioning valve?
Old Jul 18, 2017 | 04:16 PM
  #27
DiscoCam's Avatar
I opened up this line from the proportioning valve and nothing came out (coming in the side of the ABS pump). The rest of the lines going into/ coming out of the valve had fluid come out when the brakes were applied.
Is is there a way to adjust the valve?
Or reset it?
Old Jul 18, 2017 | 06:02 PM
  #28
DiscoCam's Avatar
So here is where I am right now
Front brakes work. Rear brakes do not.
The rear calipers do not get any fluid after the proportioning valve. The new master does get fluid to the valve.
I found this thread on a defender forum: Poor braking - Defender Source
OP complains about a similar problem to mine about his D90; the rear brakes don't work and cannot be bled.
At the end, the OP mentions that he adjusted the valve. But is a little unclear on how exactly. So does anyone know how? I am convinced that this is the issue as everything else seems to operate as designed.
Thanks again.
Old Jul 18, 2017 | 06:38 PM
  #29
ugh I hate when people leave out the most needed detail.
I do not know if or how it could be adjusted.
so if you have nothing coming in to the abs from the P valve,......you may have found your gremlin -
when I did my brakes the rears bleed like every other car Ive worked on and I know mine was working b/c I could hear the metal on metal when braking - hence why I was doing the brakes
Old Jul 19, 2017 | 02:35 PM
  #30
DiscoCam's Avatar
Yeah I'm pretty sure I have a bad proportioning valve. I took the existing one off the truck and tried to adjust it. I couldn't figure out how, so I just bought another from Lucky8. Might as well considering the truck is 19 years old. Another $130......
It should come in this friday so hopefully I will have a working brake system by then.
