Brake - Turn indicator fuse keeps blowing
Old Oct 23, 2023 | 08:20 AM
whiskeynipple0088's Avatar
Default *SOLVED* Tailgate Hinge replacement - Brake & Turn indicator fuse keeps blowing
*SOLVED*
Upper hinge in tailgate had trapped the defrost and brake wires - they got smashed and made contact with the body. Once free, there was enough slack to pull them both up thru the hole by the glass to make the repair (barrel connectors).
Brake light and Turn indicator use the same fuse - it keeps blowing - immediately after replacing.
After replacing blinkers work fine - I think it is blowing after depressing the brake pedal.
Im going to check the ever problematic rear tail light housing.
this started immediately after some recent work: replaced cargo door hinges - during which the cargo door was opened and shut over and over to check for proper latching. Not sure if or how that could be related.
Are there any 'check here also' recommendations. Could this be a sign of bad brake light switch?
thanks
Old Oct 24, 2023 | 07:32 PM
JohnZo's Avatar
thanks
Blown fuse means a short of 12V to ground. Try unplugging or disconnecting brake light fixtures until it stops.
The center brake light wires snake near the hinges.
Old Oct 27, 2023 | 07:57 AM
thanks JohnZo - this was it
Old Nov 1, 2023 | 02:22 PM
czerta's Avatar
Had this happen when an exhaust leak melted one of the bumper indicator clusters, the cluster wiring then spun around until they shorted out.
Its likely the wire snake near hinge but it could be bumper if that passes the sniff check
Bob Palitz
LR2
Dec 9, 2019 05:53 PM
johnaray3
Apr 18, 2019 11:22 AM
JustTani
Aug 19, 2015 09:22 AM
dankdistrict
Jan 28, 2010 11:10 PM
97XD
Oct 30, 2007 02:58 PM
