brighter instrument cluster
Old Apr 14, 2017 | 01:53 PM
Ankeneering's Avatar
As a slight aside, how hard is it/how would one change the color of the illumination? The green makes me slightly nauseous and reminds me of 80's Japanese vehicles. I would prefer the red that BMW's have. Is that a filter/plate/bulb itself?
Old Apr 18, 2017 | 09:11 AM
RedRovin''s Avatar
Some of them are bulb color and others are filter caps over a clear bulb
Old Apr 19, 2017 | 09:40 AM
redrover99's Avatar
I just did mine. The back illumination could probably be changed, however the top bulbs that shine down to light up the needles are clear. The green filter for those is part of the housing.
If you changed the ones behind it might look strange given the added green shining down from above.
If you got drastic I suppose you could remove the whole filter attached to the housing.
As a side. Changing the small lights in all the switches to the orange is pretty cool.
Old Jan 24, 2020 | 03:54 AM
Jan Suurholma's Avatar
Default 1 single black connector
hello!
can anyone tell me that is that single black connector in to of plastic cover do? on in midle near edge of picture.? is it grounding or current? mine is missing that cord...! thank you all!
Old Apr 1, 2020 | 10:16 AM
robbyb20's Avatar
4th Gear
Did you ever find out? My tach is going and i have swapped out the instrument cluster. im going to check the alt (its pulling 14.10ish volts so that shouldnt be a problem).
sickws6
Jan 19, 2016 12:22 PM
shaneb24
Jun 17, 2015 09:40 PM
Chrisinhouston
Sep 28, 2013 05:22 PM
mtrdrms
Feb 20, 2013 06:24 AM
Greg
Aug 8, 2007 04:47 AM
