Broken Oxygyen Sensor
Well.......I had the entire front exhaust dropped to replace the gaskets at the manifolds and to facilitate transmission filter change.
I planning on replacing the front O2 sensors when I started this. I mucked up the rear passenger O2 sensor in this process so was going to swap it with one of the fronts. I soaked them all with PB Blaster several times over this last week.....and......twist it off at the threads. Any suggestions?
drill it find an easy out to fit and then heat it cherry hot, install extractor and carefully extract it
or try to heat and somehow screw it in all the way till it falls into the pipe
or drill out the center big as you can and make some relief cut into the threaded part with a hacksaw blade then chisel the pieces inward
or try heating it red hot then drill it and hope the bit grabs it and runs it into the pipe
bcolins
01-18-2015 11:40 AM
