A bunch o' lightbulbs
Old Jun 10, 2018 | 01:24 PM
vanbadri's Avatar
Default A bunch o' lightbulbs
I'm trying to replace these lightbulbs in the center instrument cluster.
PN's:
STC1878G (A/C & Recirculate button green bulb)
STC1877G (A/C & Recirculate button orange bulb)
STC881G (Gear Selector bulb)
BAU5311L (clock bulb)
I've already got the bulbs out and I know their LR part numbers. Does anyone know any other bulb numbers for these things? because I'd much prefer to shoot down to NAPA and get them if I can in order to avoid getting them through AB or similar. TIA
Old Jun 10, 2018 | 02:14 PM
OverRover's Avatar
The clear micro lamp replacement for both STC1877/8G is #7219.
When you remove the originals be careful when you take off the green/orange plastic covers so you can reuse them. You can get replacement caps if you need to.
I knew I posted this once before...
> https://landroverforums.com/forum/di...-lights-86435/
Old Jun 11, 2018 | 08:33 AM
scsand's Avatar
Just did gear replacement bulb.. got it at advance. Went with the soft white led. 2825 is the number. But I think 194 will work as well.. easy to test when you have it apart.
Old Jun 11, 2018 | 10:34 AM
WaltNYC's Avatar
bulbs without the plastic color covers...
Amazon Amazon
Old Jun 11, 2018 | 11:44 AM
vanbadri's Avatar
Thanks all, I ordered some things from superbrightleds.com, will let y'all know if they work out
partsguru
Jan 16, 2016 07:12 AM
gbob
Dec 4, 2013 07:51 AM
jdogg
Oct 2, 2013 06:44 PM
jigray3
Sep 30, 2010 08:33 AM
luxury1
Feb 28, 2009 01:10 PM
