Bypassing CEL for Cruise Control
Old May 11, 2018 | 07:08 PM
vanbadri's Avatar
Default Bypassing CEL for Cruise Control
So I recently read that if your CEL is illuminated, the cruise control is disabled. My CEL is indeed on, with an O2 code (technically the light isn’t on, P.O. cut the wire). I can’t easily remedy the code as the P.O. replaced one of the cats with straight pipe... which brings me to my question: do y’all know of any way to bypass the CEL failsafe for cruise control?
Old Jun 1, 2018 | 05:17 PM
vanbadri's Avatar
Giving this a bump, as that worked well for me last time. I'm loathe to believe nobody has any ideas or experience on this, and my lack of cruise control is really annoying.
Old Jun 4, 2018 | 03:06 PM
Llamasayswhat's Avatar
Are you sure the CEL is the cause for nonfunctional cruise control? The systems are notoriously fickle and have issues with the pump, the vacuum lines, the vacuum capsule, the brake pedal switch, and the ECU
I hadn't heard of the CEL being cause for disabling cruise before this
Old Jun 5, 2018 | 08:20 AM
vanbadri's Avatar
TBH I'm not sure, but I've pulled my pump and it is working just fine. The vacuum hoses are fine, I just replaced the actuator diaphragm (and made sure it holds vacuum). I just read somewhere that if your CEL is illuminated, cruise control is disabled by default, so I figured if that's a known issue it's the first thing to tackle. Can anyone confirm that a CEL will disable cruise control? Does anyone's cruise work with their CEL on?
Old Jun 5, 2018 | 09:35 AM
WaltNYC's Avatar
from etc manual page 80
NOTE: For 300 Tdi vehicles equipped with an EDC
Diesel engine, the Cruise Control System can also
be disabled by the Engine Control Module (ECM)
(Z132) when an engine fault has been detected.
CEL disable of cruise control only applies on 300 Tdi's.
Old Jun 7, 2018 | 10:20 AM
Paul Grant's Avatar
I'd put money on a bad ecu. I don't even bother reselling the DI ECU anymore. Too many failures. Remove the ECU, it's a silver box about the size of a cigarette pack, behind the glove box. Open it up and inspect the circuit board for bad solder joints and other issues. People have been swapping in the DII cruise control ECU as a mod to get their system working again.
Old Jun 8, 2018 | 06:30 AM
WaltNYC's Avatar
Listen to Paul. He knows about these things. FWIW I did exactly what he describes (IIRC I purchased the new cruise ECU from him) and it now works perfectly.
It is worth replacing the vacuum hoses as well. They are cheap.
discoland
Sep 6, 2023 01:42 AM
coors
Oct 19, 2013 11:55 AM
errose2002
Nov 17, 2010 08:14 PM
Robmcin
Apr 23, 2009 10:26 PM
Camdisco24
Mar 16, 2008 08:43 PM
