Cruise Control Surging
Old Apr 15, 2009 | 09:14 PM
Robmcin's Avatar
Default Cruise Control Surging
OK, fixed the cruise control, it was a cracked tube right at the vacuum canister under the hood. Now it works fine EXCEPT it surges. Set it at 70 and it will rnge from 69 to 72 or 73 , no specific rhythm, just randomly does it.
Anybody know what's up?
Old Apr 15, 2009 | 09:24 PM
AK Rover's Avatar
Recheck all your vacuum lines for leaks. Use something like liquid tape to make sure the lines aren't leaking around the fittings. If you don't find anything then search the forum for test procedure for the cruise control ECU.
Are you having any surging when you drive without the cruise control?
Old Apr 15, 2009 | 09:58 PM
Robmcin's Avatar
no, just when using the CC. Otherwise she runs very smooth
Old Apr 15, 2009 | 11:48 PM
AK Rover's Avatar
I was thinking that if the throttle surged when not using the cruise control the throttle position sensor could be your problem. Since it runs fine without the cruise I would rule that out. Check for vacuum leaks again and let us know what you find.
Old Apr 23, 2009 | 08:32 PM
04DiscoHSE's Avatar
6th Gear
My CC surges BAD and I have barely 40k on my Disco II. Its under warranty though, will the dealer know what to fix?
Old Apr 23, 2009 | 09:11 PM
There is a TSB on the cruise control, the cruise computer needs to be remapped.
Covered under warranty.
If you are out of warranty then they should fix it for cheap if not free.
Old Apr 23, 2009 | 10:26 PM
04DiscoHSE's Avatar
6th Gear
Thanks!
Evan5291
Nov 21, 2017 07:59 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
GregHaugen
Oct 27, 2006 12:44 AM
stangchic50
Jan 22, 2005 08:20 AM
lowridersvt
Nov 10, 2004 07:36 AM
