A/c fans
Old Jul 7, 2011 | 06:32 PM
All I know is if the beer in my cup holder ain't cold then theirs a problem with my a/c.
Old Jul 7, 2011 | 10:39 PM
atancreti's Avatar
I have 60 degree air coming out of the vents at 95 degrees out side.. Which seems pretty good. I don't think I could get it down to 25-35. I have a new fan clutch and hopefully that stops the overheating... As for the A/C fans, I will jump them and see if it turns.
Old Jul 8, 2011 | 05:35 AM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
But after a while the expansion valve gets clogged up and nasty, which causes the temp to raise. A slow condensor fan will not be efficient in cooling the high pressure gas to liquid. Sounds like the wires to the fan are either damaged, bent, or restrictive somewhere causing resistance. Could also be just a bad coil in the fan. Heat kills electronics components after time.
Old Jul 8, 2011 | 10:18 AM
Chris-bob's Avatar
That's just another type of temp gauge...
javarover
Jun 5, 2007 08:48 AM
carperman
Jan 22, 2007 10:51 PM
EL GALLO
Jan 7, 2007 11:24 AM
Reniam
Freelander
Nov 9, 2006 09:48 PM
SARAH1
Freelander
Oct 30, 2005 12:05 AM
