FUNNY FANS
Old Jan 5, 2007 | 11:48 AM
EL GALLO's Avatar
Default FUNNY FANS
HELLO FRIENDS HAPPY NEW YEAR!
MORE TROUBLE BOTH MY AC CONDENSER FANS DO NOT WORK .AFTER CHECKING RELAYS AND STUFF MY MECHANIC SAYS I HAVE TO REPLACE BOTH FANS.VERY EXPENSIVE NEW.ANYONE HAVE ANY IDEAS AS TO HOW I SOLVE THIS PROBLEM,I KIND OF DO NOT BELIEVETHAT BOTH FANS CAN GO OUT LIKE THIS.ANY HELP WILL BE APPRECIATED.THANKS
Old Jan 5, 2007 | 12:21 PM
Default RE: FUNNY FANS
What year truck and how many miles?
There are a number of things that could be causing this to happen. The ECU controls the fans power to the fans. Try using a test probe on the power wire to the fans, while the engine is running and the a/c is on, if you have power the fans could be bad. Try running a hot wire from the battery to the positive wire on one of the fans, does it come on?
Worst case, if your fans are bad you can buy aftermarket fans from most of the local auto part stores. I also have a good scourse for guaranteed used factory fans.
Mike
Old Jan 7, 2007 | 10:28 AM
EL GALLO's Avatar
ALL TEST INDICATE CULPRIT FANS.FOUND 2 ON EBAY FOR $66 PLUS SHIPPING,BUT IF YOU HAVE A GOOD SOURCE FOR USED PARTS FOR LANDYS I WOULD APPRECIATE YOU TELLING ME.THANK YOU FOR HELPING ME OUT.
Old Jan 7, 2007 | 11:24 AM
I just checked around, that is a good price and I would suggest you take it.
Good luck with the project.
Mike
Brad S1
Jul 10, 2006 04:06 AM
DiscoGravy
Jan 23, 2006 10:47 AM
kumbhani123
Dec 13, 2005 11:29 PM
05LandRover
Off Topic
Nov 1, 2005 05:19 PM
05LandRover
Off Topic
May 4, 2005 01:00 AM
