can newer headlights fit on my Rover?
Old Feb 27, 2014 | 10:08 PM
gonebaby's Avatar
Default can newer headlights fit on my Rover?
I have a 97 and I really like the look of the 04 on head lights can they be mounted? Thanks Rob
Old Feb 27, 2014 | 10:42 PM
abran's Avatar
I have heard you can if you change the fenders to 03 or 04 fenders. But I'm not sure the body lines are the same.
You can put 99-2002 D2 headlights on your 97. They are not as fancy, but have black around the outer edge. Both my D1s have the early D2 headlights.
Old Feb 28, 2014 | 07:35 AM
fishEH's Avatar
You can do it but its a big pain in the butt, and I believe there's no going back. A google search should turn up something.
Old Feb 28, 2014 | 07:57 AM
TOM R's Avatar
It is doable by just making upper brackets for the housings iirc there is a thread with pics showing the conversion, no changing fenders was needed
Issue is those housings are like $400 each and hard to find good used
The standard d2 are a nice direct fit upgrade they are on mine check my thread
Old Feb 28, 2014 | 09:33 AM
EricTyrrell's Avatar
Yes but it's lots of cutting and the fit and finish depends on your skill. Those headlights are expensive and plastic anyways.
Old Feb 28, 2014 | 10:57 AM
dusty1's Avatar
I, for one, like the glass better. On d2 (not d1) I went from glass to new plastic.....I like the old better.....more rugged looking
Old Feb 28, 2014 | 03:56 PM
digitalb3's Avatar
anybody use these head lights on a d1 before ?
HEADLAMP UPGRADE KIT FOR DISCOVERY I, RNK9923 - Kit Configuration Page
Old Feb 28, 2014 | 07:30 PM
TOM R's Avatar
Those are just d2 head lites cheaper at a junk yard think I sold a set for under $100 shipped?
Old Mar 1, 2014 | 12:28 AM
m1943's Avatar
I know for a fact that it's possible, I have a friend who's got '03 headlights on a mid-1990s Disco. But it's not plug and play, there is some dremeling involved and also they will need to be re-wired. I had a similar conversion done on a D2 back in the day, and those headlights were never a very tight fit against the fender, so it all looked kinda sloppy, but that was probably just done incorrectly. Plus the headlights from eBay had some tabs broken off.
Old Mar 1, 2014 | 12:59 AM
digitalb3's Avatar
Mine are fine. I have a city bulb out in one that I need to replace.
