Can someone help with my Power Steering Leak
Hello Good People,
Looks like the day has arrived and my power steering is leaking serious fluid. It doesn't appear to be coming from the hoses or the reservoir. I opened the hood and took this image standing in front of the drivers side fender. The leak appears to coming from underneath. The yellow circle points to the section in question.
What am I looking at in terms of fixing?
Is there a temp fix to get me out of this jam? Some kind of temporary puddy patch or something?
Its below freezing outside and I thought I was done with being under the hood for the Winter.
Thanks in advance
Thanks in advance
Hello All,
Here is an update on my leaking power steering.
First off the leak was bad! For the last 11days it has been pouring out, as in refilling the reservoir every morning before driving to work, and again after work before heading home. I tried the BlueDevil Transmission Sealer but can't say it actually worked due to the amount of miles needed to drive the car before sealer would start working. I read the forum for days and came across a 2015 post by OverRover saying to use Lucas Transmission Fix in the power steering and not the PS stop leak. It worked! The truck went from having ATF fluid pouring out to now seeing a few small drops on cardboard over night.
Much thanks to the awesome members that have posted and shared their knowledge over the years.
Respect,
Respect,
