can't find a test for
I was looking through the RAVE manual, and I can't find a test for the HVAC blower motor resistor. Does anyone know if there is a test?
When I turn on the blower motor, all I'm getting is a click. It used to run on one speed only, now, not at all... I hope it's just the resistor, as the blower motor appears to be pricey.
the switch (fan speed) tests good.
ok, back out to it...
any and all (on and off topic) suggestions welcome!
ok, NOW, back out to it.
how cheap is cheap?
I have a "working" blower motor now, for how long, I dunno.
I pulled the brushes out filed them down, cleaned up the surface they ride on, and it works.
cleaned the contacts in the switch while I had it apart, still only one speed. I think I need the resistor.
the A/C blows ice cold though!
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
Location: Oklahoma; where the winds come rolling down the plains.
on
Here is what I have. Can't find the resistor pack, must not have pulled it off my 97D1.
https://landroverforums.com/forum/me...y2026-2923.jpg
In the electrical troubleshooting guide. Section K1, page 6, shows the diagram of the resistor module, should have 4 wires. It would appear pin 1 to pin 2 would read a single resistor and what looks like a fuse of some sort. Pin 2 to Pin 3 reads across another resistor. Pin 3 to Pin 4 reads across the third resistor. So reading pin 1 to any other pin should have a reading. And any that don't indicate an open. Normally when you open something like this up it is either coils of wire, or the resistors are burned beyond being able to read the values.
If you short pin 4 and pin 1, it should blow on full speed until replacement parts arrive.
Evian
06-23-2006 01:59 PM
