carriers
Old Feb 12, 2015 | 05:02 PM
FLA Rover's Avatar
Default carriers
Had a busted spyder gear in the rear and thanks to Paul Grant it's all fixed. Got it back together and went to test drive and noticed a issue on the front end. Pulled the fill plug and looked inside where I find the carrier split into. Can anyone tell me if the front and rear carriers are interchangable? If they are I can use the rear to replace the front.
Old Feb 14, 2015 | 09:26 AM
TOM R's Avatar
I would call Paul and ask, he should know
Old Feb 14, 2015 | 09:43 AM
fishEH's Avatar
Front and rear are the same. Its one of their biggest strengths and weaknesses. Its good because you can swap diffs easy. Its bad because the front tires are being driven on the coast side of the ring teeth, this is why you'll see aftermarket front R&P sold as "reverse cut".
Old Feb 15, 2015 | 12:25 PM
stephenspann27's Avatar
Known as "low pinion" in the jeep world. I didn't know that about the Disco..
Guest66
Defender
Feb 2, 2012 08:31 AM
Paul64
Jul 30, 2007 09:38 PM
