Cat Delete
Old Jul 21, 2023 | 09:03 PM
88gtblack's Avatar
Default Cat Delete
95 Morgan Plus 8, has a 95 rover 3.9 v8 with the mechanical maf
the car i bought has no cats, and i know these are motors that are supposed to have them. I'm definitely not adding them, the maf is set to 1.0 volts. Seems to have a put every once in a while out of the exhaust, I'm checking timing tomorrow. Question is, aside from setting the maf to 1.0 volts, what else am I supposed to do for the cat deletes to kind of clean up the exhaust smell?
I have that issue, and it runs a little warm (225 degrees )
Thanks in advance everyone!!
Old Jul 22, 2023 | 11:47 AM
Harvlr's Avatar
Is it GEMS, 14CUX? Does it have/need O2 sensors?
Old Jul 23, 2023 | 10:16 AM
Best4x4's Avatar
14CUX has 2 O2 sensors before the cats. Removal of the cats has zero effect on it.
Old Jul 23, 2023 | 10:30 AM
JohnZo's Avatar
Can you check fuel pressure? Fuel pressure regulator? I recently purchased a fuel rail off a '96 that has a schrader valve to check fuel pressure, but not installed yet.
Recent addition to my '94 3.9L was a 3.0 bar (44 psi) regulator. Spec is 2.5 (37), no vacuum condition. This has caused occasional backfire, with more smell when started cold. Still in a trial period. New regulator has 3.0 etched onto the cover near the vacuum port.
Another recent addition was a Flowkooler water pump and URO ERR3443 original spec standard duty fan clutch. Using a genuine LR thermostat (88 deg C, 190 deg F). Coolant temp up to 205 F (195 F typical) when driving slowly around town at 100 F outside temp. Gets a bit hotter waiting in a line. Last year, it got up to 222 F in a parking lot, A/C on for over ten minutes, 100+ outside.
Hope this helps.
Old Jul 28, 2023 | 02:04 PM
hrhoward's Avatar
Ran w/o cats on my '97 for about 2 years. Had a couple spark plug non fouler bungs welded in downstream then O2's into those. No codes.
Ben Matheson
May 10, 2019 06:59 PM
sloppyjoe
Nov 23, 2010 06:42 PM
Ericshere03
Feb 16, 2010 05:28 PM
Roverpatsfan
Sep 16, 2009 08:16 PM
tomfraser
Mar 19, 2009 09:25 PM
