cd changer
OK since my disc changer drowned when I took the rover swimming I scored another at the u pull that powers and ejects so. 2 questions
I need to get the discs and cartridge out of the dead one
I need ideas where to mount the new one so I do not kill it
if your cd player powers on, the rest is easy. Discs do NOT need to be in the player at all.
https://landroverforums.com/forum/di...tion-d1-52617/
OK swapped changer for now and works fine
Now I did get the cart out of old changer easy
Remove top and bottom covers look to see if a disc is in reader, mine was not since I was not using it when it died
Be sure door is open
On the bottom at the back under cartridge there is a lever, slide it to the side and presto cartridge ejects
If there is a disc stuck in the reader I am unsure if it will eject, if I'd does you may need to mess with the disc stuck in there
I still need a dryer location for it
As a side note, my rover 1998, donor rover 1998 both did changers dated august 1999 wtf??.
