cd changer
Old Aug 20, 2013 | 10:06 PM
TOM R's Avatar
Default cd changer
OK since my disc changer drowned when I took the rover swimming I scored another at the u pull that powers and ejects so. 2 questions
I need to get the discs and cartridge out of the dead one
I need ideas where to mount the new one so I do not kill it
Old Aug 20, 2013 | 11:06 PM
ihscouts's Avatar
Really? Who uses CD's anymore? Mount it in a trash bin and buy yourself a modern head unit.
Old Aug 20, 2013 | 11:47 PM
CUpgt's Avatar
I like my stock setup! I usually rock the radio though
Old Aug 21, 2013 | 07:28 AM
TOM R's Avatar
I like my old school tech I still use tapes in my other vehicles rover deck is inop, and yes I do own an iPod
Old Aug 21, 2013 | 08:48 AM
WaltNYC's Avatar
if your cd player powers on, the rest is easy. Discs do NOT need to be in the player at all.
https://landroverforums.com/forum/di...tion-d1-52617/
Old Aug 21, 2013 | 10:19 AM
Whilst wading you "discovered" the built in water level detector and the sound stopped.
Old Aug 21, 2013 | 10:28 AM
dusty1's Avatar
do tell, when you get the old discs out. mine is holding a stones box set hostage.
Old Aug 21, 2013 | 11:00 AM
fishEH's Avatar
If the CD player isn't working anyways why not just tear it apart and get your CDs out?
Old Aug 21, 2013 | 09:01 PM
TOM R's Avatar
OK swapped changer for now and works fine
Now I did get the cart out of old changer easy
Remove top and bottom covers look to see if a disc is in reader, mine was not since I was not using it when it died
Be sure door is open
On the bottom at the back under cartridge there is a lever, slide it to the side and presto cartridge ejects
If there is a disc stuck in the reader I am unsure if it will eject, if I'd does you may need to mess with the disc stuck in there
I still need a dryer location for it
As a side note, my rover 1998, donor rover 1998 both did changers dated august 1999 wtf??.
Old Aug 21, 2013 | 09:27 PM
dusty1's Avatar
cool. on it! thanks
