change rear drive shaft or not
Old Oct 1, 2011 | 07:56 AM
landyman2's Avatar
Default change rear drive shaft or not
hi folks i have just bought a 95 disco and own a 93 range rover, my question is i want to put my 2inch lift out of my range rover into the disco but the rear prop shaft with the rubber on it should i change to a range rover one or just leave it there i did notice that the yoke would have to be changed would the range rover one go in i do have a spare and how do you remove the yoke in the disco thanks Luke.
Old Oct 1, 2011 | 03:49 PM
antichrist's Avatar
I'm assuming you're adding the lift because you off-road. The rotoflex will get torn up impacting things off-road.
For removing the 3-bolt flange,
LR Special tool, or
Slide hammer, or
3-Bolt Flange Removal
Old Oct 2, 2011 | 09:37 AM
I have run a rotoflex for 118,000 miles over trails in Death Valley, Rubicon, the California high desert, Moab and many Colorado trails, and I haven't torn up a rotoflex yet with my near 3" lift. Just check it for crack between the 6 bolts and replace if needed.
DiscoJon
Jul 14, 2019 01:51 PM
VTRover
May 15, 2014 09:05 PM
collin Barrows
Aug 28, 2011 07:13 AM
TripleThreat
Apr 12, 2011 08:58 AM
