Chevy Express Fan Clutch COMPLETE
Old Aug 29, 2012 | 10:33 AM
Scharfire's Avatar
Default Chevy Express Fan Clutch COMPLETE
So i did what everyone else did with the fan clutch and put in a 2000 chevy express v6 fan clutch. Ran into some issues with taking off the original fan clutch. once that was off i could not get the 4 bolts to remove the fan. ended up drilling the bolts out. drilled out the holes to be able to except the new ones to 3/8's inch. the chevy fan clutch pushes in the fan about 1 and 1/8th inch. due to this i had to grind some of the fan away to keep it from hitting the fan shroud. ended up rounding the outer edges of the fan and taking off about 1/16th off the top of the fan. no more issues and works great.
Old Aug 29, 2012 | 10:51 AM
jafir's Avatar
How much did this clutch cost?
Old Aug 29, 2012 | 12:06 PM
$47.99 at Auto Zone near me, p/n 922626 - you want the one "without" AC, it is a six inch diameter and fits, the "with AC" is a 7 inch diameter and is more difficult to fit.
Old Aug 29, 2012 | 06:42 PM
$50, lifetime warranty.
Old Aug 29, 2012 | 07:37 PM
Scharfire's Avatar
paid 40 bucks for mine
Old Aug 29, 2012 | 10:40 PM
Racer X's Avatar
Two questions:
- Is this a standard duty fan clutch?
- Will this clutch work on a Disco II? I'm aware that the holes on the fan will need to be enlarged to 10mm...
Old Aug 30, 2012 | 06:36 AM
yes and yes. Standard duty usually means that at "re-coupling" when heated up, power transfer is about 60-70%. Heavy duty is 90%, impacts MPG more. When at normal operating temps, both are coupled at maybe 20%. But don't try to test that by grabbing moving fan blades. Or you could have a new nickname - "Stubby" .
Also if experimenting, fan clutch from late 90's early 00's GMC or Chevy will fit. I have one from a 2000 Blazer. Same water pump threads, same diameter and rotation, $19 at junk yard. I realize that not everyone wants the shame of driving a truck with partz vulturz feathers falling off of it, but there are more Chevy/GMC than Rovers in the boneyards of North America.
MC04DII
Feb 27, 2014 08:43 PM
99Discovery
Jan 19, 2014 01:07 PM
94svt50
Mar 30, 2013 09:27 PM
Lincoln Tarantino
15
Jul 3, 2012 03:02 PM
ogden45
Nov 19, 2011 01:46 PM
