chevy g80 diffs in a disco 1
Old Mar 27, 2012 | 12:10 PM
deer4011's Avatar
Default chevy g80 diffs in a disco 1
i was just wandering if ia could put a chevy g80 diff on my 1999 disco 1. its just alot cheaper to get than a detroit or arb.
Old Mar 27, 2012 | 12:19 PM
Chris-bob's Avatar
Do you mean the entire axle, or just the diff? I doubt the diff alone is a bolt-in. The entire axle could be done, but how much time and money do you have to accomplish the swap?
Old Mar 27, 2012 | 12:23 PM
deer4011's Avatar
i was just thinking the diff becuase its an everyday driver and i think swapping axles could take too long
Old Mar 27, 2012 | 12:31 PM
Chris-bob's Avatar
You'd need to do some measuring and all. I doubt it'll fit only because noone's said anything about it yet(could be noone thought of it till now...). But, the LR diff is pretty stout from what I understand, and not too expensive to replace. Throwing a auto-locker isn't too bad either. If the g80 did fit, what is the benefit?
Old Mar 27, 2012 | 12:37 PM
Jake1996D1's Avatar
No it wont work, completely different. More common swap is toyota diffs cause they are 30-spline and much stronger however it's not a direct swap either. None of the options are cheap. Except for buying an american vehicle and upgrading that..
RovingTracks Extreme Duty Land Rover Drivetrain Accessories - contact Keith he know everything there is to know about custom axles/diffs on a rover
Old Mar 27, 2012 | 12:50 PM
deer4011's Avatar
i was just trying to see if a g80 to fit because they come stock in z71s and i could pull one off a dead one. but if they dont fit do the toyota diffs come locked stock.
Old Mar 27, 2012 | 12:54 PM
Jake1996D1's Avatar
Nope but the lockers for toyotas are usually cheaper.. You're gonna have to buy axles regardless if you're running lockers, stock rover axles will break.
Old Mar 27, 2012 | 01:00 PM
deer4011's Avatar
how much would an axle swap cost me and would it be possible to do it with a chevy.
Old Mar 27, 2012 | 01:01 PM
Chris-bob's Avatar
Anything is possible. Check out the link that was posted earlier. Great info in it.
davidrover
Sep 3, 2013 05:35 AM
aussiedisco
Feb 23, 2010 07:36 AM
starcraft
May 19, 2008 07:15 PM
bklahl
Aug 30, 2007 07:58 AM
95DiscoSE7bullitt
Feb 27, 2006 10:33 PM
