Chevy power steering pump swap success
Old Feb 25, 2011 | 04:36 PM
joverrover's Avatar
Default Chevy power steering pump swap success
I have a 94 disco and swaped the bad LR steering pump with a 92 S-10 4 cyl pump. There was no problems saved $$$ Thanks to who first did it.
Old Feb 25, 2011 | 04:38 PM
1997rangie's Avatar
do you have some pics of what it looks like?
Old Feb 25, 2011 | 06:28 PM
kenk's Avatar
Was it a straight forward swap, as in any mods needed to make it work?
Old Feb 25, 2011 | 07:24 PM
1997rangie's Avatar
well...
I am building a winch bumper for my rangie.
its main component is a HMMWV hydraulic winch. i might have to upgrade the power steering pump ... so if the one you put in has similar mounting points i should be golden
Old Feb 25, 2011 | 08:11 PM
Danny Lee 97 Disco's Avatar
Originally Posted by 1997rangie
well...
Are you planning on using the power steering pump to drive the hydraulic winch?
Old Feb 25, 2011 | 08:26 PM
1997rangie's Avatar
yes , the H1 power steering drives this hydraulic winch
and so I was planning to do it on the range rover.
only hurdle could be the fact that the LR power steering pump has a higher flow rate. that's where i would change the thing out for a HMMWV pump and cooler to go with it
Old Feb 26, 2011 | 09:28 AM
joverrover's Avatar
It was straight forward, it bolted right up the only mod was and a ben in the line and getiing a fitting to make the connection because it was different on the chevy pump.
Old Feb 26, 2011 | 11:07 AM
1997rangie's Avatar
cool that's great news did the pump you used look similar to this one?
Old Mar 17, 2011 | 12:37 PM
swank1975's Avatar
Advance Autoparts Part # SP16327They say you can pick up the hose with the 90* bend for like $15 also to adapt the only difference.
Another thread..
https://landroverforums.com/forum/ar...p/t-35013.html
Old Mar 17, 2011 | 09:42 PM
antichrist's Avatar
You loose a lot of the advantage of a hydraulic winch running it off the PS pump, namely 100% duty cycle. Also, there are reports of the steering box not holding up well to the added pressure of uprated PS pumps.
A PTO pump would be a lot better solution.
