clanging exhuast pipe
Old Jul 20, 2014 | 04:54 PM
HammerFit's Avatar
Default clanging exhuast pipe
Did I read somewhere that if timing is off you will here a clanging sound coming from the exhaust pipes when you start to pull off, or did I dream that?
Old Jul 20, 2014 | 05:07 PM
MonteroMan's Avatar
Mmmm let us give the grey stuff something to do...
1. There may pre-ignition and pinking and that may sound to some like undue exhaust noises?
2. There may be uneven firing and rough engine response and shaking and a loose exhaust support may cause that at speed, as will slight backfiring?
Old Jul 20, 2014 | 05:29 PM
HammerFit's Avatar
Engine runs and sounds nearly flawless. Only issue is the slightly high idle, which I have exhausted all options looking for.
I am not going to mess with the tamper proof idle adjustment.
Exhaust piping all good.
It's just gives out a metal clanking sound, (like 2 or 3 times when you start out in first gear. Only happens then.
Old Jul 20, 2014 | 08:22 PM
MonteroMan's Avatar
Default Torque?
Torque causing a touch? Engine mount rubber worn or broken?
Old Jul 21, 2014 | 06:06 PM
ihscouts's Avatar
Probably the resonator tapping the rear body mount.
instg8r
Jun 22, 2010 06:30 PM
raid13
May 13, 2007 12:13 PM
gwalker
Apr 14, 2007 12:03 PM
Tim444
Mar 13, 2006 11:17 PM
mach1al
Jun 20, 2005 08:23 PM
