clicking sound
Old Feb 5, 2011 | 01:47 PM
I dont know if low diff fluid could cause this type of noise or not.
Check all of your sway bar connections too.
Old Feb 5, 2011 | 02:16 PM
Rover Chris's Avatar
sway bar connections? the rear sway bar probably is past due for new bushings and what not, I did notice where the rear sway bar mounts to the frame (through the thick clamp down bushings) that there was a bit of a clean spot on the sway bar lust to the side of the bushing, like it slightly moved to the side and slid through that bushing mount just a bit (maybe a 1/4" of clean spot) I will try to take a picture later if you don't know what I mean.
just wasn't sure how that would be a part of this problem. It sounds mechanical and could possibly be coming from the rear driveshaft.
Old Feb 5, 2011 | 05:26 PM
Danny Lee 97 Disco's Avatar
Have you made sure all your exhaust system boltts are tight? Mine leaked right at the Y pipe flange due to a burned thru gasket. It clicked like crazy.
Old Feb 5, 2011 | 10:08 PM
the clicking is definitely related to the drive shaft or rear axle/wheel. after listening to it some more today I am thinking it is the U joint in the back, it is tough while driving to determine where a sound is coming from, to me while driving it was back and right so I figured right rear wheel, but back and right could also be the rear drive shaft and the rear differential.
Old Jan 11, 2021 | 12:27 AM
Stephen Ferguson's Avatar
I have the same issue and it has since started to lock up in the rear randomly. From what I hear there is a pin in the rear diff that can back out and rub against the splines on the diff. May have to source a new rear differential.
hemicharger69
Dec 17, 2015 11:57 AM
kamileon
Apr 27, 2011 05:23 PM
csb
Jun 5, 2010 08:27 AM
blcp86
Aug 29, 2009 01:22 PM
Camdisco24
Mar 21, 2007 10:03 PM
