Clicking sound
Old Apr 26, 2011 | 01:36 PM
kamileon's Avatar
Default Clicking sound
So over the past few weeks Ive noticed a sorta clicking sound coming from the under side of the D1. The only time I hear it is when I drive through our tunnel to get to work, yes I work in an underground facility. Im driving less than 10 mph and can hear it echoing off the walls, so far its the only place and time I can hear it. Im going to dive under it this weekend and have a look but wanted to get some opinions on what to look for and at, or hoping this is normal. It kinda reminds me of my old jeep, I had detroit lockers installed and they clicked when you would go slow and turn, but in this case Im not turning just going straight.
Old Apr 26, 2011 | 01:43 PM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Check the tires for a rock stuck in the tread or for foreign matter such as a nail or screw. Eliminate the simple things first. If you have time, jack up each wheel seperatley and check for play, possibility of bearing wear or constant
velocity joint trouble.
Old Apr 26, 2011 | 02:21 PM
Chris-bob's Avatar
Is the clicking sound similar in speed to the rotation of the tires, driveline, engine?
Old Apr 26, 2011 | 02:40 PM
kamileon's Avatar
See thats whats throwing me off, the sound is not consistent and doesnt seem to be in relation to the same speed as the tire or driveline rotation.
Old Apr 26, 2011 | 06:49 PM
Long Haul's Avatar
Check for exhaust leak if its not constant with rotations. My nuts come loose where the pipe bolts to the manifold occasionally and makes a slight ticking noise.
Old Apr 26, 2011 | 07:40 PM
Tomorrow while driving in your tunnel shift into neutral and then shut off the engine while still moving, if the noise is still there its not engine related.
Old Apr 27, 2011 | 05:23 PM
jbriggs's Avatar
Two things that do the same thing on mine: The covers that ar part of the lug nuts and the center cap on the wheel. See if they are a little loose. If they are the stock D1 rims this can happen. It took me weeks to figure it out.
domyo
Sep 25, 2008 12:19 PM
snorlax
May 8, 2008 12:08 PM
CL_Reatta
Mar 7, 2008 01:47 PM
gildedsplinters
Feb 5, 2008 09:55 AM
Northernlight
Mar 4, 2006 04:32 PM
