Clutch Issue
Clutch Issue
Replaced the clutch over the last couple of days. Got everything back together today and the clutch pedal goes to the floor. Tried bleeding it, no help. I 'think the pedal doesn't travel as far as it used to. Clutch pedal worked fine before replacing clutch. I did accidentally push the clutch pedal while the slave cylinder was removed from the bell housing, not sure if that could have done something. I unbolted the slave cylinder and my wife gently pushed on the pedal and the slave cylinder began to push away away from the bell housing.
1994 Discovery I. 5-Speed. All stock except for bumpers.
I'm thinking I broke the slave cylinder. Any ideas would be a great help right now.
Thanks,
Derek V
Thanks,
Derek V
Hmmmm, sounds like you have it covered. Usually it's either a leak (and you'll see fluid somewhere) or air in the system. I haven't had to deal with the system on the Disco (other than a small bleed four years ago) - but have done a couple on older GMs. Can't recall how the slave cylinder looks on the Disco - but if you can, park it on an incline to get the cylinder at an angle to help any air get out through the bleeder when bleeding the system. Have run into that situation in the past.
Took some 0.32 wire and made sure both holes in the reservoir were clear, no problem there. No leaks. Oddly, the only time my wife felt pressure pushing the pedal down was with the bleed valve open and fluid coming out.
Slave cylinder is ordered. Ill get it swapped out and the system bled as soon as it arrives.
Derek V
Derek V
No need to drop the exhaust. I'll look at which sockets and wrench I need tomorrow when I swap it. With some extensions I go above the exhaust from the front and the socket fits right on the the two bolts holding it on. Again, ill check, but i think a 9-inch and a 6-inch extension works perfect. I think they are 10mm. Probably a 13-14mm for the hard line.
