Code 49
Old Sep 1, 2023 | 08:25 PM
Dclick's Avatar
Default Code 49
Hey guys first time posting. My rover is throwing code 49 on the display under the passenger seat. I tested the display by making it throw another code and the leds are not burnt out, it is displaying code 49. I did some research and this code doesn’t seem to exist. Has anyone run into this before? Thank you
Old Sep 2, 2023 | 07:40 AM
94Disco1's Avatar
Agree code 49 doesn’t show up in the conventional lists. Assuming the secondary codes you made it throw covered the section of “8” that make “9” on the second number?
One thing you could do is setup the free RoverGauge program on a windows laptop/tablet and purchase or build the required cable. That will show you the code that the ECU is trying to show at a software level directly without any under seat display module confusion.
Old Sep 2, 2023 | 05:18 PM
Dclick's Avatar
thank you for the response. I will get this setup and give a shot
Old Sep 3, 2023 | 03:24 PM
JohnZo's Avatar
Here's a thought. If the lower left segment of the second digit is bad, then a 48 code will look like 49. Code 48 is for IACV stepper motor trouble.
Jmiller78
Jun 19, 2022 12:48 AM
Bbg
LR2
May 26, 2021 10:59 AM
film842
May 2, 2015 10:21 AM
vithooantony
Defender
Nov 25, 2014 11:23 PM
gavone1976
Nov 19, 2012 02:00 PM
