Codes P0118 / P0125
Old Jun 9, 2015 | 08:52 AM
BG Simons's Avatar
Default Codes P0118 / P0125
This weekend my 96 Discovery 1 had difficulty starting on several occasions.
Seemed to be running extremely rich nearly flooded in fact
Pulled codes yesterday which were -
P0118 - Engine coolant temp. sensor high out of range fault
P0125 - Engine coolant temp. sensor warm up fault
Would replacing engine coolant temp sensor (two wires) fix this problem? This is near the thermostat ?
Once running everything seems fine.
Thanks in advance.
Old Jun 9, 2015 | 10:30 AM
jafir's Avatar
Does the engine ever warm up? Where does the temp gauge sit? Probably it's the sensor, but just making sure it's not a thermostat issue.
Old Jun 9, 2015 | 11:42 AM
BG Simons's Avatar
The engine warms up fine as it always had no issues there. Thermostat / water pump changed about 15,000 miles ago. Temp gauge also operates as normal and settles in a just a hair below 1/2.
discosophy
Apr 17, 2011 11:43 PM
BajaXJ92
Dec 3, 2009 07:43 PM
kaz
May 13, 2008 09:10 PM
Nitro96
Dec 22, 2007 08:27 PM
apcollin
Dec 5, 2007 09:53 PM
