Cold starting TDI problems
Old Jan 17, 2011 | 03:36 AM
curly's Avatar
Default Cold starting TDI problems
Hi,
Can anyone help with difficult starting on a 300 tdi 1995 discovery. Engine otherwise fine I think as just done 2000 miles in 3 days no bother. Done about 110000. Its also a jap import if that makes any odds and is an edc? model.
The vehicle is fairly new to me, but prob seems to be getting worse. Previous owner replaced cambelt. New glow plugs fitted. It fires first time but now always stalls and requires 3 or four attempts before starting. Then runs smoothly.
Any help greatly appreciated as the vehicles has to do another 2000 miles shortly.
Thanks
Old Jan 17, 2011 | 12:52 PM
Long Haul's Avatar
Im not that familiar with the rover tdi but ir sounds like a glow plug relay or glow plug controller. The glow plugs arent staying on enough to start and run properly. Its that or the fuel is draining back into the tank.
Old Jan 17, 2011 | 06:08 PM
It could also be cheap fuel, a dirty fuel filter or its just way to cold for it.
Without knowing where you live its hard to know if weather is a factor.
But if its below 0*F and its not being plugged in at night with a block heater cold start/run problems will be a issue.
Old Jan 19, 2011 | 05:22 AM
curly's Avatar
Thanks for those ideas. I know the plugs are doing something as the battery voltage drop when the plugs light is on? I will check the fuel issues though.
I'm fairly far north (orkney north of scotland uk) but same fault happens in warm ish temp or when very cold. Maybe a block heater would be good too... I like the diesel preheaters but they are expensive!
Dan
Old Jan 19, 2011 | 07:12 PM
A block heater might be pricey but well worth the money.
dirkha
Feb 10, 2021 06:44 AM
mattmo78
Nov 21, 2013 01:23 PM
pkppunk
Jan 26, 2013 07:05 PM
Budvar
Dec 20, 2007 06:12 PM
mark.peters
Freelander
Feb 10, 2007 07:59 AM
