Colored Snorkels: Who's intersted?
#32
But seriously, when you get your design down, I'll take a flat black one, Mantec style
#33
Location: Oklahoma; where the winds come rolling down the plains.
on
I have the first prototype design figured out. Was up all night pushing numbers into the computer. Stumbled onto an interior design that demonstrates the best air intake breathability and reliability compared to the hollow straw design. This design is solid, easy to install, will not be intimidated by impacts and is very affordable. The exterior however is not what anyones expects. When this is finnished and you compare it to whats out there, huh; it's like comparing cheerios to fruity pebbles. Very excited to get to North Carolina and start working on the prototype and casting. Again I appreciate everyones input. One area that I still need some more input on is the top, head attachment. One great suggestion was to have it rotate 360 degrees. Need more suggestions please. Also would the filter location be more beneficial under the hood and attached to the MAF for easy cleaning. Or mounted in the head or somewhere within the tube. There is no real difference with concern to the engine. I noticed Safari uses a piece of crappy foam in the head.
#34
Filter in the engine compartment.
WHO could have had such a great idea about a rotating head.....hmmmmm
I hope this top secret design isn't too far off the beaten path as to dissuade people from buying it. It still needs to look like a snorkel, if it looks like an elephant trunk (even though I requested that verbatim)...I'm returning it
As far as heads go if you've ever seen that Toyota one with the enclosed fish bowl look I, personally, DON'T Want that. I want something more in line with the mantec and safari tops. The safari top has those rain flutes which is an added bonus. But the spinnable head should help with rain intake too no? As long as you remember it.
#35
on
The rain or water splash is taken care of with the interior design. One thing I have found is that when air travels into the tube it follows a direct and mostly continuous path. Those so-called rain slats are not entirely an efficient design. I wonder if they actually tested that concept. My software allows me to construct a 3D image and introduce variables. What I have found is that an interior design must be constructed to stableize the continuous and fluctuating rush of air. Current designs allow the water and air to travel together in a common pattern. A large percentage of the straw is actually unused, pressure wise. The so-called rain exits are based off of this pattern. Unfortunetly if the head is not directed properly, it distorts this air flow, renduring the rain exits near useless. The angle has to be perfectly alligned in order to work efficiently. I have found an interior design that will act as a drier, while maximizing the intake air to pressurize the entire space, which helps further cool the air. This allows for a more maximized stable air flow and eliminating the moisture more efficiently. Yeah I don't like the bowl filter head either.
#36
#38
#40
