Coolant spraying... 95 discovery
Thanks again everyone. Will order with WP on monday and tackle this next weekend.
Still am not clear if my symptoms would cause a leak though. I cannot track down the source of the leak, but the best I can figure is that it is coming from right around where the pulley is...
will report back after I replace the WP.
Does Autozone etc.. have a decent equivalent water pump, or should I order it from a rover parts place?
Pump is probably only leaking when the engine is running, then the fan is blowing the coolant back on the engine, hood, and everywhere else. You would never know if you had another leak till you get the pump fixed. I am betting that is your only problem
