Coolant spraying... 95 discovery
Old Feb 6, 2011 | 12:55 PM
Danny Lee 97 Disco's Avatar
Originally Posted by mattrickman
The whole front end? Won't it just be the radiator, fan, belt and pulley/water pump? What else would I take care of?
I did not mean the front end of the vehicle, just the front of the engine basically. Take a good look at the serp belt, hoses, and such. While you are in there do a good inspection. There is a small trainsmission fluid cooler behind the grill right in front of radiator. The hose going to one side of mine developed a pinhole and I thought I had a power steering fluid leak, it took forever to chase it down.
On my 97, I have been pre-emptive and try to replace as much weakened original items as possible when I do tear into it such a major way.
Old Feb 6, 2011 | 09:31 PM
mattrickman's Avatar
Danny - Gotcha.. Thanks. Just wanted to make sure I wasn't underestimating the job.
"On my 97, I have been pre-emptive and try to replace as much weakened original items as possible when I do tear into it such a major way." I need to start doing this more pro-actively.
Old Feb 10, 2011 | 12:54 PM
Should I go ahead and replace the fan clutch?
Old Feb 10, 2011 | 02:37 PM
Chris-bob's Avatar
Replacing the fan clutch only hurts the wallet. It the pump is that bad, chances are the clutch may have taken a beating it didn't deserve(or maybe it did...).
Old Feb 10, 2011 | 05:33 PM
Yes, read the tech section for a less costly fan clutch option.
Old Feb 10, 2011 | 06:23 PM
With one that old, I definitely would and the serpentine belt too if it's not already new.
I don't like to take mine apart any more times than I absolutely have to. I would also plan to replace all the hoses as well especially if they are original or not very recently replaced. I go ahead and buy as much new smaller hardware as possible so that next time around it is not an even bigger problem.
Old Feb 24, 2011 | 11:29 AM
Replacing the Water Pump fixed the coolant leaking/spraying issue. Job was fairly straightforward. Clutch came off easy (rented a fan clutch removal kit from O'Reilly) Hardest part was removing the water pump pulley.
Old Feb 24, 2011 | 02:16 PM
Did you replace the fan clutch as well or did you put the old one back in?
je2242
Oct 28, 2011 05:29 AM
bobmaucher
Sep 11, 2011 07:46 AM
SurfingRover
Mar 12, 2008 06:47 PM
bigugly82
Dec 31, 2006 03:13 AM
camcor
Aug 10, 2005 11:07 AM
