couple question on 300tdi conversion
some things im still unsure of. looking to start in the next few months
does the pedal box bolt right in?
does the transmission fit on the original mounts?
do i leave my original wiring harness there and wire the 300 into it? or pull it out completely?
i just learned about glow plugs so im kinda curious how long it takes to start the 300. if you have to wait at all even.
any good walkthroughs on the conversion? or maybe somebody in las vegas haha
are 300tdi's with a/c as rare as the first ad says?
thanks!
thanks!
The glow plugs go on for about 5 seconds and then you can start the engine. Mine kicks over pretty much immediately.
Apparently a/c is a pretty rare option on the 300tdi in Europe, I'm not sure how rare it is in hotter countries such as Australia.
- Matt
ps. I just noticed that I've been a member of this site since 2008 and this was my very first post. I'll put up some info on my D1 in the near future.
- Matt
what ive found so far
there is a relay for the glow plug timer and works just as you said jafir.
pedal box bolts in
change the crossmember and the transmission will fit
still a little confused on the ecu. seems like that will run the windows, locks, a/c etc. im hoping they will still work even though there wont be an engine as far as it knows. ill be swapping clusters to have the glow plug light and no check engine light(not that it really matters)
hoping the power steering and clutch line will drop in from the donor vehicle but still unsure
pedal box bolts in
Right now your automatic cooling lines run to the radiator and then to a second cooler mounted behind the bumper. when you install the manual tranny you will only use the second cooler and will no longer need the radiator cooler. you will also need to find the reverse light wiring on your transmission and the neutral safety wiring. Permanently jump the neutral safety wiring so that you can start your rover. If your using a transfer case from an automatic you will also need to remove the shift interlock solinoid
