Which crank sensor?
Old Mar 20, 2017 | 11:11 AM
hrhoward's Avatar
Question Which crank sensor?
Ok,
I have a 1998 engine in my '97 and I think the crank sensor/wiring is flaky. Hit puddle in driveway at >10 mph or rain overnight sputters and can't get over 10-15 mph. After a bit and it warms up, runs great again.
Anyway, which one do I need? PC714 (Standard Motors) or a ERR6119? Both on Amazon.
ERR6119
PC714
https://images-na.ssl-images-amazon....L._SL1056_.jpg
Old Mar 20, 2017 | 04:38 PM
ihscouts's Avatar
ERR6119 is the correct part number.
Old Mar 20, 2017 | 05:32 PM
hrhoward's Avatar
Good. That's the one I ordered.
Planning on it curing stumble/sputter after wee puddle at driveway speeds and when wet prior to starting.
Old Mar 20, 2017 | 11:00 PM
robertf's Avatar
check the wiring first. both gems trucks i've owned had insulation damage that caused those problems. Seems the wiring for the crank sensor is only good for 15ish years
Old Mar 21, 2017 | 12:12 AM
ihscouts's Avatar
^Spot on.
Thanks for your adaptives reset work by the way, read the Dweb thread.
Old Mar 21, 2017 | 06:19 AM
WaltNYC's Avatar
I've been under the impression that Standard PC579 would also be correct. I CANNOT however verify that.
Amazon Amazon
Old Mar 21, 2017 | 08:24 AM
notny41's Avatar
Can someone please shoot a picture of where the crankshaft sensor is on these vehicles? I'm beginning to wonder about mine. RAVE isn't much help on the location of this. Just some arrows of where to start looking for it on the car.
Old Mar 21, 2017 | 09:28 AM
ihscouts's Avatar
Drivers side, opposite the starter.
Old Mar 21, 2017 | 09:44 AM
OverRover's Avatar
https://www.amazon.com/dp/B001TEMGEY...I1JE3H5MOHWMXE
>> You can SEARCH parts from STANDARD MOTOR PRODUCTS (& all of their other brands) here ( CLICK OUR BRANDS & eCATALOGS )> http://www.smpcorp.com/en/?msw=1
Old Mar 21, 2017 | 02:48 PM
hrhoward's Avatar
Here are some pictures. ihscouts is right, opposite side of starter.
Attached Thumbnails Which crank sensor?-img_3896.jpg   Which crank sensor?-img_3899.jpg
