Crankshaft Position Sensor Maintenance ('98 w 168k)
Hi all, as stated on title wanted to get some input on the crankshaft position sensor. I've done some readings and seem to see more threads on this for the series II and not so much on DI but definitely some that cause no start issues. Some have mentioned keeping an aftermarket spare incase it goes since it will disable the car.
My questions?
I don't have a problem keeping a spare in case it goes out in the field but am I better off just replacing the sensor as a maintenance item?
Also all the threads seem to point to aftermarket sensors vs OEM, seems aftermarket is okay.
Just looking to avoid some potential headaches while out in the mountains.
Thanks
My questions?
Thanks
vserduchka
12-04-2009 05:57 PM
