crankshaft position sensor, can't reach???
Old Sep 16, 2010 | 01:26 PM
ViennaDisco's Avatar
5th Gear
Default crankshaft position sensor, can't reach???
Ok so what am I doing wrong. I found this post which was perfect https://landroverforums.com/forum/sh...+sensor&page=2
Except I cant reach the darn thing. After almost breaking my my arm I was able to take the cover off and I could probably do the same for the two 8mm bolts holding the sensor. But there is no way my arm will reach the connector. The exhaust is too close to the frame for me to get my arm (i have small arms) all the way up to unplug the sensor. I really hate to remove the exhaust bolts, even then I'm not sure it would move enough without removing both sides. BTW I am working from the bottom with the wheel removed.
2003 Disco
Old Sep 16, 2010 | 02:56 PM
agthird's Avatar
someone posted about having some long needle nose shaped pliers as being the golden egg...
Old Sep 16, 2010 | 11:41 PM
5th Gear
Thanks, looks like I will probably have to tow it to a dealer. I was able to remove the old one. Now there is no way to reach the connector to plug the new one in. I have zero leverage to hold the top connector in place. Why didnt LR make the harness 6 inches longer....
I'm very impressed with you guys that got it installed under 60 minutes. I have been battling it for over 5 hours.
Old Sep 16, 2010 | 11:49 PM
lordmorpheus's Avatar
If I remember correctly, when I replaced my engine (which came with the CSS already installed), I made the electrical connection from above. I do not remember if that was done before or after the manifold was installed
Old Sep 17, 2010 | 12:22 AM
5th Gear
I just found the video that was posted of the install, and I noticed the exhaust was disconnected from the manifold. I guess I will try see if I can remove the bolts tomorrow morning before I give up. Strange the video looks like the exhaust is hanging a good 3-4 inches below the manifold, I didnt think there was that much room. But it is late and I already started drinking another beer.
Old Sep 17, 2010 | 06:05 AM
Bundu's Avatar
Banned
Loosen the 2 bolts at the other end of the Y pipe as well.
It is very easy to replace the crank position sensor once the engine is out
Old Sep 25, 2010 | 04:16 PM
gwhiz72's Avatar
Default video
could you share that video link?
EVN137
Oct 6, 2024 12:48 PM
southern_disco
Oct 9, 2010 06:28 PM
hendoc3
Jun 25, 2010 11:56 AM
vserduchka
Dec 4, 2009 05:57 PM
smi8387
Feb 7, 2006 01:15 PM
