Crankshaft Postion Sensor Mount Flopping Around
Old Oct 16, 2018 | 06:18 PM
  #21
ihscouts's Avatar
^That's a cool thing to do, good man.
Old Oct 22, 2018 | 02:26 PM
  #22
hrhoward's Avatar
Originally Posted by aemnky606
If you need an intake manifold let me know I have one on the shelf. It will need some cleaning but it is yours if you need it.
aemnky,
Thanks! I'll keep that in mind.
Old Nov 4, 2018 | 01:59 PM
  #23
hrhoward's Avatar
Default That was fun
Old Nov 5, 2018 | 08:55 AM
  #24
hrhoward's Avatar
Default Pictures of the Crank Position Sensor Bracket with engine out
Crankshaft Sensor Bracket
Crankshaft Position Sensor Bracket
Old Nov 5, 2018 | 09:28 AM
  #25
aemnky606's Avatar
I would check the teeth on the flywheel to make sure they are not bent/missing. There defiantly has been some contact there.
Old Nov 5, 2018 | 03:08 PM
  #26
hrhoward's Avatar
Amazingly, none were bent. Well, until my bar slipped when I was unbolting the Torque Converter.
Old Nov 5, 2018 | 05:26 PM
  #27
ihscouts's Avatar
Oops. Sure can tell the motor had a few miles on er. You have two quarts of oil just waiting to be changed on the outside of the motor..
Old Nov 5, 2018 | 05:34 PM
  #28
hrhoward's Avatar
That's its winter coat.
PO had a rover cannibal motor dropped in 15 years ago.
Head gaskets & up and oil pan gasket are all I'm going to worry with.
Old Nov 5, 2018 | 05:45 PM
  #29
ihscouts's Avatar
Does it winter in Siberia? Looks like a baby seal, probably would float in a kiddie pool.
I like the plan, why put allot into it if the guts are good...... although wasn't there issues with the Cannibal motors..........? You know, If I had my motor hang'n on a string I'd zip a 4.6 crank n rods in it just for giggles. You never know, you might fall in love with it all over again.
Old Nov 6, 2018 | 03:56 PM
  #30
hrhoward's Avatar
Baby seal. Good one!
The engine was running great right until I crawled under it and yanked out the crank sensor.
As far as slapping a 4.6 crank & rods in there, I'd rather go the LS 6L80E route.
Just had the cats gutted for chits and giggles. (cut out and pipe welded in their place)
Sandman614
Jun 14, 2020 10:12 PM
cmshoot
Feb 9, 2018 12:25 AM
Jeff Blake
Dec 31, 2016 02:27 AM
Rabih A. Yaghi
Aug 8, 2013 05:04 PM
hootiewales
Jul 30, 2011 05:49 PM
