Crappy new steering box fix
Old Sep 23, 2011 | 12:05 PM
Chris-bob's Avatar
Originally Posted by WaltNYC
That looks like a 'square' O ring, correct?
I was about to post the same thing. That is definitely a square o-ring. You need to go to a hydraulic shop for a replacement. Not a auto parts or plumbing parts store. The hydraulic shop can usually source the correct one for under $10(including shipping to your island, about the same as my island)
Old Sep 23, 2011 | 12:26 PM
antichrist's Avatar
If your mechanic can get an accurate measurement with calipers, ID, OD, cross section size, I can probably find you one here in Atlanta and mail it to you.
Old Sep 23, 2011 | 01:52 PM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
I have extra top plate seals I can send you for free. They are from rebuilds, but never leaked. PM me if you want it.
Old Sep 23, 2011 | 03:55 PM
slanginsanjuan's Avatar
yes, Walt. It is a square O ring. BTW do you have a front right window channel for me? How's the city? I miss it. My Rover does not.
I think I should get the proper O ring as well. If I find it then I will have a perfectly new box I believe. I may be optimistic but I think the rest of it is fine.
Even with my Mitutoyo Digital Calipter (don't ask) it's pretty hard to accurately measure a rubber O ring and the new one is too small but the old one surely has morphed since it was made.
Savannah, hilarious you know Casa de Tornillo (house of screws - hot bordello). I was there last week looking for stuff. I've been to a far range of places lookin' for it here.
Old Sep 23, 2011 | 04:01 PM
...thanks guys...ill try to measure it and identify it and then let's see what we can do.
Old Sep 23, 2011 | 09:56 PM
alpinacsi's Avatar
Make sure you get the correct material as well. With power steering, trans and hyd fluid you will need a buna-n seal which is very common. I have 100s of thousands of square cut o-rings in stock but only in about 15-20 sizes. If you have the measurements; I can see if I have anything and if not I will see if I can get what you need. McMaster is an excellent resource if they will ship to you,
Most jewlery stores have a tool to size rings that works well to assist with measuring orings: slide your o-ring on the tool and measure where it stops.
Todd
Old Sep 23, 2011 | 10:25 PM
britishracinggreen's Avatar
Maybe a longshot here but do you have a construction equipment dealership near you (caterpillar, etc...)? That is a D-ring and they are commonly used on their hydraulic pumps in thousands of sizes. They may be able to match one up for you in their service/parts department.
Old Sep 25, 2011 | 01:08 AM
pedronz's Avatar
i would suggest you are wasting your time measuring the o ring itself, i would measure up the groove width, internal diameter (ID), the housing dia (OD) and give those measurements to a industrial seal/hydraulic shop, they can, from the those measurements, figure out the correct size ring for the job, all seals/o rings or what ever have very specific crush sizes for it to do the job correctly (not leak) you have a old steering box there i gather so measure that.
cheers
Pedronz
Spencerfitch
Aug 13, 2013 01:27 PM
greenharoguy
Jan 2, 2013 05:01 AM
hondoptc
Jun 9, 2011 03:15 PM
UpChuck
Apr 19, 2011 09:54 AM
lipadj46
Oct 29, 2009 03:10 PM
