Cruise control almost fixed, maybe
Old Oct 11, 2013 | 09:17 AM
Trooper1276's Avatar
3rd Gear
Default Cruise control almost fixed, maybe
Ok I've had this 98 Disco for a few months now and have worked through almost all of the issues that are common with these things. I am down to the cruise control. Replaced VAC lines. Last week went to the pick n pull and pulled a diaphragm a Vac pump and the silver cruise ECU from under the dash. I replaced each component went for a drive and repeated with no success.
A few days later I tried it headeding down the free way and it worked! Ran some errands and haven't been able to repeat the success.
The one time it worked I was able to turn it on, off, accel, ect. It seemed to be in perfect order but nothing since then.
Any help would be great!
Thanks
Old Oct 11, 2013 | 10:17 AM
Shiftonthefly1's Avatar
There is a thread floating around that someone changed over to the later model ecu. They too were having a similar issue as you. He said he swapped multiple used units to no avail. Once he converted it worked.
Old Oct 11, 2013 | 02:34 PM
TOM R's Avatar
Go to the jy get a d2 cruise unit same general location iirc it says cruise on it, get the plug with as much wire as possible, remove d1 cut out d1 plug wire in d2 plug, cruise unit fits in same area
There are 2 d2 units one has an extra wire that is not used on d1,either 1 works, I did the switch and started working but think I lost the relay now
Old Oct 11, 2013 | 03:08 PM
denverdisco1's Avatar
Thanks for the info, I think I will tackle that next
Old Oct 11, 2013 | 03:10 PM
TOM R's Avatar
Find the thread, it shows making a adapter, just change the pigtail But it shows wire colors they are close but you may need it
Old Oct 11, 2013 | 06:52 PM
3rd Gear
Default D2 ecu
I'll try that thanks guys
Evan5291
Nov 21, 2017 07:59 AM
Rover Chris
Sep 25, 2010 09:55 PM
Timpala`
Feb 2, 2010 05:44 PM
southfloridadiscoII
Jun 28, 2009 11:03 PM
Elhoff
Oct 21, 2006 03:18 PM
