Cruise Control Button Not Working
Old Feb 8, 2012 | 05:15 PM
Marnold-98-Disco's Avatar
Default Cruise Control Button Not Working
my cruise control button isn't working in my dash cluster. the light isn't coming on and cruise isn't setting... ?
Old Feb 8, 2012 | 06:42 PM
hh65flyer's Avatar
I have the same issue. Of course check fuses, etc. I also checked power to the switch...all to no avail.
Old Feb 8, 2012 | 06:54 PM
deer4011's Avatar
check the vacuum lines at the drivers side firewall in the engine compartment there should be a T where 3 lines meet. just replace them thats what i did and now it works fine.
Old Feb 8, 2012 | 07:05 PM
EricTyrrell's Avatar
The cruise control vacuum pump and tubing often gets clogged up. Check that.
Old Feb 8, 2012 | 07:46 PM
If it will not light up at all and the fuses are good, then it is a cruise ECU issue, replace it.
Old Feb 9, 2012 | 01:31 PM
hh65flyer's Avatar
Where is the cruise ECU physically located? I'd like to check mine for loose connections, etc.
Old Feb 9, 2012 | 01:58 PM
WaltNYC's Avatar
Might it not be the switch itself? I've replaced nearly all my dash/binacle switches over they years.
Old Feb 9, 2012 | 08:04 PM
Cruise control ECU is behind the glove box. It has several friends packed in there with it.
Old Feb 9, 2012 | 10:00 PM
calebbo's Avatar
So if I don't even get a light (it is the one with a road and a skateboard in the middle right?) then what are my first steps to diagnosis? I check the power first?
Old Feb 10, 2012 | 10:54 AM
Chris-bob's Avatar
I don't get a light either. I also don't have any cruise components left under the hood. Might want to check to see if your cruise wasn't removed by a PO.
