Cruise Control Fail and Speedometer Fail
Old Jan 1, 2021 | 12:02 AM
DiscoNewbe's Avatar
Default Cruise Control Fail and Speedometer Fail
Hey Everyone,
was on a long 12-hour drive tonight when my cruise control cut out twice. A couple of minutes later Speedometer went to zero, then started flopping around. After about ten minutes speedometer normalized and began working again.
I’m thinking this is a faulty Vehicle Speed Sensor, but was hoping ya’ll would weigh in.
RPM, Temp, and Fuel functioned normally throughout all of this.
thanks
Old Jan 1, 2021 | 06:48 AM
disco96sd's Avatar
yes classic VSS failure - BPU has them
Old Jan 2, 2021 | 08:02 AM
jimvw57's Avatar
When y VSS acted up, speed would drop to about 35 MPH and after a bit would start working again. Some sort of limp mode I guess. speedometer would work but OBDII readout was crazy spikes. replacing the VSS took care of it. Cruse never worked on mine.
Old Jan 2, 2021 | 10:25 AM
WaltNYC's Avatar
yes, VSS. Also, do yourself a favor and get a 6" 3/16 hex tool. The parking brake cable and other assorted stuff will prevent short hex sockets from into the hex head bolt which holds the VSS in place. Something like this.....
Amazon Amazon
I spent 40 frustrating minutes doing something that should have taken 5 because I did not have one.
Old Jan 2, 2021 | 10:48 AM
disco96sd's Avatar
Thanks Walt - excellent advice - tools make the man !
discoland
Sep 6, 2023 01:42 AM
KarlS+9
Aug 27, 2020 02:27 AM
Street Wolf
Jun 9, 2011 08:35 AM
Xrover
Jun 5, 2011 10:43 AM
kwilkins
May 17, 2011 03:05 AM
