Cruise control issues
Old Oct 14, 2013 | 07:39 PM
wrongway1's Avatar
Default Cruise control issues
I know it's not vacuum related as all of the vacuum lines have been replaced & this precedes them being replaced. The cruise control works just fine for about 10, maybe 20 miles, and then shuts off. Sometimes it will reengage by pressing the set button again and go a bit before shutting off again, but most of the time it won't work for a couple of days after shutting itself off, and all of a sudden, it starts working for a bit as stated above & quits. Ideas??
Old Oct 14, 2013 | 09:31 PM
TOM R's Avatar
Bad ecu? Change to a d2 one, just swap ecu and plug
Old Oct 15, 2013 | 08:19 AM
wrongway1's Avatar
Okay, I'm lost... Are you talking about my DI ECU that runs everything in my vehicle for a DII, or is there more than (1) ECU??
Old Oct 15, 2013 | 08:52 AM
binvanna's Avatar
Cruise Control has it's own ECU.
I have a D1 with a ECU that tested good about 18 months ago. Cruise control was working until a vacuum line came off the thing under the battery tray. I fixed the lines, but no dice. I sort of doubt it's the ECU since it did test good before.
Old Oct 15, 2013 | 06:15 PM
wrongway1's Avatar
I doubt it could be the vacuum lines as it did the same thing before I had all of those replaced. Since it works when it wants to, it would have to be electrical, right?? Off to find a cruise control ECU.
Evan5291
Nov 21, 2017 07:59 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
PatRyan
Mar 10, 2008 11:39 AM
Core_Shot
Jan 28, 2008 07:55 PM
dherbs85
Nov 26, 2005 04:52 PM
