Cruise Control Issues
Old Nov 16, 2005 | 03:45 PM
dherbs85's Avatar
Default Cruise Control Issues
WHere can i locate the vacuum for the cruise control, I understand that this could be cracked and the reason why it is not working. THanks
Old Nov 23, 2005 | 12:40 PM
DJAC's Avatar
Default RE: Cruise Control Issues
Check the vacuum lines near the jack. This is where I found my problem, however if its not vacuum, then its the dreaded black box... FWIW get yourself the factory manual, its worth the $100 bucks
Old Nov 26, 2005 | 12:08 PM
Hank's Avatar
There are also vaccum lines hear the brake master cylinder that run to the top of the motor.... Be sure you check the fuses too I think over at Discoweb.org there was a write-up on fixing this issue....But, I have not looked there in a while...
Old Nov 26, 2005 | 04:52 PM
mikemeyer0's Avatar
you have a vac line running from the cruise vac pump, under the driver headlight, that goes to the firewall right by the master cyl. and T's off to intake area, there is a plunger looking thing there, forget the name, and from the T, it also goes into the cab to the brake pedel itself, there is a little valve body that releases vac when you press the brake.
Evan5291
Nov 21, 2017 07:59 AM
MoShadeTree
Jan 2, 2013 11:34 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
PatRyan
Mar 10, 2008 11:39 AM
Core_Shot
Jan 28, 2008 07:55 PM
