Cruise control questions...
Old Feb 27, 2012 | 07:01 PM
Chris-bob's Avatar
Originally Posted by hh65flyer
The airbag is what I'm afraid of... :-O
It only hurts for a minute...
Old Feb 27, 2012 | 08:47 PM
JumPeR04's Avatar
thanks matt, and on the air bag, just use rubber gloves lol....
Old Feb 27, 2012 | 10:29 PM
hh65flyer's Avatar
You guys are really filling me with confidence! I may be checking in again soon JumPer depending on what I find back there. Hopefully I won't be needing the airbag too!! ;-)
Old Feb 27, 2012 | 11:20 PM
JumPeR04's Avatar
just let me know matt....
Old Feb 28, 2012 | 11:53 AM
psykokid's Avatar
I'm in the same boat troubleshooting my cruise control system. Good thing is if you cant find a rover in the yard to pull a vacuum pump from, VW's used the same pump and connector in their cars from 89 to around 95. After 95 to about 2000 they switched to a different connector but its the same pump. I havent laid hands on the CC ECU but i think it may be the same style hella unit that the VAG cars use. It's not a complex system overall. Vacuum units and switches on each of the pedals, vacuum motor, on/off switch and set speed switches as well as a VSS input to the CC ECU.
I replaced my steering wheel switches this past week. Nothing to it, disconnect the battery, two torx bolts hold the bag onto the steering wheel, three 10mm bolts hold the horn / airbag securing plate to the steering wheel which you need to remove because the wires for the switches are routed behind said plate.
Old Feb 28, 2012 | 01:57 PM
hh65flyer's Avatar
Did the switches fix your problem Psykokid?
Old Feb 28, 2012 | 02:35 PM
psykokid's Avatar
nope, new steering wheel switches did not fix my problem. Next up is to test the pedal switches and the vacuum pump itself. I have an extra vacuum pump from a later VW which has the different plug but will be easily adaptable if the pump turns out to be the culprit.
Old Feb 28, 2012 | 09:25 PM
Originally Posted by ptschram
The pump won't run unless the vehicle is moving at more than 35 MPH.
the cruise will work at 25mph, I do it everyday because my street is 25mph and it is strictly enforced.
Old Feb 29, 2012 | 11:57 AM
psykokid's Avatar
well, i tested my pedal switch last night, no problem there. Hooked up the pump to 12V and tested that it was ok as well. swapped out an extra cruise switch, same thing. Checked and made sure the system held vacuum and it did as it was supposed to. Only other thing i can think to check is the main brake switch or the cruise control unit itself. Fuse for the cruise circuit was good as well fwiw. On a side note, i was lookin at the connector for the cruise pump while i had everything apart yesterday and what do you know, it had a vw part number and a tiny VW logo on it.. I'm guessing its probably the same hella cruise control ecu that VW uses so that leaves me with a wider supply of donors to pull bits from at the breakers. the brake vacuum switch is the same style and connecter that VW uses as well..
Old Feb 29, 2012 | 06:31 PM
Let us know when you get it figured out and if you find cross reference for parts, we LOVE part alternatives.
