Cummins diesel D1!
Old May 21, 2018 | 03:30 PM
LS probably wouldn't be any worse MPG than the rover motor
Old May 21, 2018 | 07:39 PM
ihscouts's Avatar
Oh yeah it would cuz who doesn't like the sound of an LS wide open?
Old May 21, 2018 | 07:47 PM
you get over that after a bit
said no one ever
Old May 22, 2018 | 03:07 PM
whiskeynipple0088's Avatar
Originally Posted by ihscouts
You'll want a 30 gallon fuel tank with that LS.......
while that may be true - Ive spent many of hours researching a diesel swap and consistently reach the conclusion of 300tdi as the only real logical option
Mercedes - to slow
Cummins - rattles apart vehicle
Toyota - requires entire wire harness ecu, instrument cluster and ignition assembly
Isuzu- good luck sourcing one in good shape for under 10k and relocates tcase
all of these options including the 300tdi have the looming 'where would I source parts if on the road far from home' issue.
LS+4l80E+marks trans to tcase adaptor - if my math is correct is actually 1" shorter than stock engine and tranny
tcase location remaining unchanged.
part of the appeal to me for this setup is - no matter where in the us and likely canada - I could blow up a ls or tranny and source a used one easily.
Old May 22, 2018 | 04:54 PM
ihscouts's Avatar
I'd change one thing, dump the 4l80e for a 6l80e. During your "hours of research" did you read this thread: GM Gen 4 conversion including LS - Defender Source It now takes days to read.
Old May 23, 2018 | 08:35 AM
that link isnt working for some reason (nor is the site sorta) but I think that was in FourWheeler mag - not a whole lot of detail - Two-Letter Defender: An LS-Powered Land Rover that goes as good as it looks
yeah the 6l80e is sweet - but also much more $$
its all just a dream at this stage
Old May 29, 2018 | 07:24 AM
Saturnine's Avatar
Dirt Everyday got their hands on it for the weekend apparently.. Probably won't be on the show but the host got to romp around in it for a few days
Old Jun 7, 2018 | 07:59 PM
oh dam I mispoke - missed this was the R2.8 not the 4bt - from the pics I thought it was the 4bt -
but dam 9k for the engine....
found the build thread
https://www.repowerowners.com/forum/...over-discovery
Last edited by whiskeynipple0088; Jun 7, 2018 at 08:13 PM. Reason: found the build
Old Jun 7, 2018 | 09:04 PM
ihscouts's Avatar
Not a 4bt which is a 3.9l and is only $5k in long block crate style. Have you looked into the International HS 2.8 TGV yet?
Old Jun 8, 2018 | 12:58 PM
Yes I have heard of it but I have had a hell of a time finding info on it - pretty much gave up on it as I figured if its that illusive online - finding parts and service support would be nill.
But Im all ears if you got some sources.
