Current Project
Old Jan 10, 2011 | 05:43 PM
Bajapower's Avatar
Default Current Project
Always wanted a winch bumper, so last week instead of ordering one, i built one myself. The main bumper is A36 Steel Channel 7 x 2 x .210 (9.8#) welded to A500 Steel Structural Square Tube 3 X 3 X 1/4 wall frame extensions bolted to frame with Grade 8 bolts. Winch sits on a 1/4" pre fabbed winch plate we had to modify for use. D rings are 15,000# welded to bumper face at extension locations. Winch was mounted as low as possible, but entire Assembly is actually higher than stock bumper, so more ground clearance. Need to fab up a skid plate to protect steering.
Old Jan 10, 2011 | 07:04 PM
jdracersc's Avatar
What a Monster! How much does that puppy weigh fully loaded?
Old Jan 10, 2011 | 07:09 PM
Roverrocks's Avatar
Nice Job. Much lower than I would want but it looks pretty good. I always commend people that can fabricate things. I couldn't do that for sure.
Old Jan 10, 2011 | 09:19 PM
Bajapower's Avatar
Steel stock ~ 107 lbs
winch~ 80 lbs
roller fairlead~ 10 lbs
Winch mount plate~ 25 lbs
weight of D-shackles~???
so excluding the weight of the shackles we are around 222 lbs.
Old Jan 10, 2011 | 09:20 PM
Bajapower's Avatar
Thanks.
Bottom of the channel steel is only 3/4" lower then the stock steel bumper.
Old Jan 11, 2011 | 05:42 AM
jdracersc's Avatar
winch~ 80 lbs
That's a bit heavy...LOL That would look right at home on a Superduty haha... Good job though,I like seeing personal projects come together. My first Disco bumper didn't come out so hot. I'm workin on a new design.
Old Jan 11, 2011 | 07:43 AM
hilltoppersx's Avatar
that bumper is not bad looking just need to remove that whole front bit and it looks like a slimline from Rovertym or TF.
Old Jan 11, 2011 | 12:46 PM
Danny Lee 97 Disco's Avatar
Nice job. I like the old cowcatcher front ends they used on locomotives. Maybe one of those push bumpers like some law enforcement and tow trucks use.
Massive unit. How does that weight affect handling and such? Do you have heavy duty springs up front?
I have seen old trucks with 2 by 12's or even logs mounted on the front.
Old Jan 11, 2011 | 03:03 PM
Bajapower's Avatar
handling isnt to different, but you can tell there is an extra 200 lbs up front.
Stock springs, a set oh HD springs are on their way. It crunches the front pretty good. Wish i had taken some before and after measurements to see just how far it sunk.
Old Jan 11, 2011 | 05:00 PM
jdracersc's Avatar
Hell, I'm trying to sell this bumper so I can start building another one.
